engine that smokes...
raymo8
1985 Evinrude <br />6.6 HP <br />2 Cycle Longshaft <br /><br />I just bought a 14' starcraft with a 6.6 hp engine on it. The engine may be older than a 1985 though because although the seller told me that it was a 1985, it was painted which leads me to believe that it may be older. Anyway, it runs fine except for excessive smoke that constantly comes from the engine. It seems to go away somewhat when I put the engine in gear but smokes too much when it is in neutral. I'm hoping that maybe the guy that I bought it from mixed too much oil in with the gas (the ratio is 50:1) but this might not be the case. Does anyone have any suggestions. Thanks.
JB
Re: engine that smokes...
Hi, Raymo.<br /><br />I suggest that you read the replies to the first time you posted this question. If you have more questions, post them as replies on your original thread.<br /><br />Good luck. :)
