Re: engine temp?
Ya, Raw water cooled, run the 140* T-stat... It's the salt that's Desolved in seawater, that crystalizes in the porous cast iron, that causes the problems... you'll NEVER Flush it out at the higher temps.... My boat is raw water cooled, I boat in fresh water 99% of my time, But I Still run the 140* T-stat.....<br />Yes, Thermal effeicency is at about 195*, I'd Switch to the 180* T-stat IF you're running Freshwater(closed system) cooling.....<br />Merc.'s New EFI motors with the closed cooling system, run higher temps....So the 'puter doesn't richen the mixture too much....
