Engine tach rpm drifts at 4000-5000 rpm
22trophy
My 1999 Mercury force 120HP's rpm drifts,this occurs at constant throttle and engine sound. This leads me to believe it's an indicator problem. I believe there is no direct cable from engine to dash board. So I may have a problem with a voltage regulator, or my charging system. Does anyone know how I would proceed from this pt? Thanx.
andy6374
Re: Engine tach rpm drifts at 4000-5000 rpm
Are you sure you are not losing speed? <br /><br />If not, make sure the connections at the rectifier are tight and free of corrosion. If the battery is charging properly and you have a good connection between the yellow and grey wires at the rectifier then there is either a short in the wire harness or the tach is bad. Try a known working tach before purchasing a new one though.
Texasmark
I'm gonna guess here. Tach's that I remember had a rotating part and a stationary part (internally) . The rotating part had a magnet on it and a piece of steel. The faster it spun the more times the magnet influenced the steel and pulled harder on it. Hence the needle would deflect more and more. But if your needle is dragging because of dirt, which is nonuniform around the circle, the needle would hang and get free and so on. The faster it turned the more noticable it is.<br /><br />I'm going to guess that your tach is dirty and these little jewels (that the needle pivots on) need a bit of maybe WD 40; something real light preferably with some cleaner in it. Or maybe pour on some alcohol and hit it with 20ish pounds of compressed air to blow out any crud (keep the air pressure low so as to not damage the little fine parts). <br /><br />Jewels (if used) don't need lubrication (like in a watch....I remember Bulova used to have 21 jewels in some), but yours may not be jeweled. If metal on metal would need some oil I'd think.<br /><br />I have a service manual but is says nothing about the care and feeding of instruments.<br /><br />Mark
