FirstTimeSeaLegs
- Apr 10, 2013
- 13
Greetings everyone. New to the forum as of today. I recently purchased a 1981 23' Carver Montego cabin cruiser with a 260 Mercruiser. I had a feeling the engine would need to be replaced before I bought it, and after getting the motor "un-seized" found that cylinder #4 had a nice 3" crack in it. So, I went on a search for a new engine and found a steal of a deal on a late 60's early 70's Chevy 350 block. Has new cam bearings (no cam), and also has the cross hatch in the cylinders. Anyway, I noticed that the oil dipstick is on the opposite side of the block compared to the original boat motor. I was thinking of just using the truck/car oil pan seeing how the original pan won't work due to the dipstick notch being on the wrong side. A concern I have is the baffle that is in the original pan. It is also oriented/made to accommodate the original tube from the original dipstick. Is the baffle a requirement? The 350 block I have for a replacement does NOT have 2 dipstick holes as I've read about on some blocks.
I plan on using the heads, water pump, and everything else I can from the boats original Mercruiser 260, leaving me only changing the pan (if possible), and the freeze plugs. Also if the dipstick placement is a huge issue, could I replace it with an after market mechanical Pressure gauge and also an electric oil level sensor?
Looking for any advice as I've never built a marine engine, but I've built a few pro street engines. Thank you in advance!
