Engine Swap 99 to 87 Merc 3.0 No power when key is "On"
KingMarine
Hello there, long story short.. I have a 2000 party barge pontoon that the Mercruiser 3.0 had to be swapped out of. We replaced both the engine and outdrive with a functional 87 Mercruiser 3.0. The primary issue is that the engine will turn over and start while it is cranking, however it seems to lose all power when you let the key rest in the ON position? I did notice that the connectors match up but one wire is missing in one of the connectors. In preliminary pinout lookups I believe this wire is not related to power or ignition, perhaps audio warning alarm? Any help is appreciated.
achris
More fish than mountain goat
:welcome: aboard.
If you're not losing instrument power in the ON position, then that symptom is usually an indicator that the resistance wire (in the engine harness) has failed...
Chris.........
use a DVM and start at the key switch and start looking where you loose voltage starting at the key switch.
I have gone thru 2 key switches on my current boat since 2011 because the "run" terminal was worn out
KingMarine
Thank you for all the input. This last weekend had to work on my wife's truck. Will be back out there Saturday trying to figure out the culprit.
