engine surges at idle stalls on acceleration
venture22
I have a 1987 Johnson 225 Looper. At cold start, the engine will start but will periodically surge (every 2 seconds revs up and down). Adjusting the throttle has no effect. I am not sure if pressing on the enricher has an effect. After a while running, the surging will stop, but then when I try and accelerate, the engine will bog down and stall if I don't take the load off the engine. If I am persistent, I can get the boat running normal. It will then run fine and re-start fine till the next outing.<br />I have new plugs, wires. I did my best to check for air leaks by replacing clamps and tie straps. <br />Could this be a fuel pump problem?
Goodoleboy
Re: engine surges at idle stalls on acceleration
Hi 22!<br /><br />It sounds to me that mabey your just abit to impatient. Give it two or three minutes to warm up at idel.<br /><br />I know uh few minutes of warm up time seems like forever when their are other people waiting to launch or load on the trailer.
