TYPE OF VESSEL: 1987 FOUR WINNS 245 VISTA HID: 4WNNY005F787
YEAR OF MANUF: 1987
Can you please help?
I own the above 1987 245 Vista. When I bought the boat it had a 454 big block Mercruiser with an Alpha Drive. I experienced a problem whereby the engine would simply cut without warning and refused to start for a period of up to 15 ? 20 minutes. It would then run happily for maybe an hour or sometimes less. I have now changed the entire configuration to a modern 5.7 ltr MPI with efi and a Volvo sterndrive. I have not changed the electrical wiring at all and I am experiencing the same problems. The engine will run fine for a period and then suddenly stop. Just as before it will start after a short rest and then run for another short period. We have checked and re-checked the fuel system and we are convinced that there is no fuel problem. It seems to be electrical but we just can?t trace the fault. I have unplugged cleaned and reinserted the big round plug carrying the electrical harness connections to the engine. Everything seems fine there.
Can you suggest a possible cause?
Thank you
Patrick
YEAR OF MANUF: 1987
Thank you
Patrick
