I have an 80HP Mercury outboard. Yesterday I tried to start the engine and it engaged for about 2 seconds and then just immediately stopped. Very sudden and no slowing winding down, just stopped without starting. I checked the battery and found it was a bit down, so did a full recharge over night. Tried to start the engine this morning and just get a click. Removed the flywheel cover and found the bendix on the starter in the engaged position against the flywheel, but the teeth were not aligned, like they should be. Tried to tap the bendix down with a hammer and piece of wood, but it would not go down. The engine has had quite a bit of work this past year by a professional mechanic to include/ rebuilt carbs, new plugs, reconditioned flywheel, new stator, new rectifier, new impellers and pump. The engine has been running quite well and has only had "non ethynol" gas in it since I got the engine last year.
Any thoughts? My best guess is have the starter checked out first to see if it froze up.
