I have a 1983 70 hp Johnson that stalls when you put it in gear. It starts and idles fine but dies when you try to put it in gear. The carbs have been rebuilt, the gas is good, compression is okay and it has new spark plugs. I took apart some of the fuel lines to clean them and opened the fuel pump as well-could that have any effect?<br />Thanks for the replys<br />Martin
