Engine stall and shutts off when suddenly dropping out of high throttle and gear.
TampaBoater
Ok, Break out another grand, right? lol
I have a 305 gm 5.0L with a mercarb,while in muffs, i kick it in gear, throttle up slowly, all is good. Throttle up quickly, hesitates. When I quickly drop out of high throttle, engine stalls. I am thinking it's got something to do with carb adjustment? Maybe? I looked at the online manual provided here, and I have located the section for adjusting the carb, but just wanted to check with the epxperts here to see if this is the problem. Also, there is a bit of hesitation when throttling up quickly from idle.
Thanks,
Les.
Re: Engine stall and shutts off when suddenly dropping out of high throttle and gear.
I have a 305 gm 5.0L with a mercarb, i kick it in gear, throttle up, all is good. When I quickly drop out of high throttle, engine stalls and sometimes even shuts off. I am thinking it's got something to do qith carb adjustment? Maybe? I looked at the online manual provided here, and I have located the section for adjusting the carb, but just wanted to check with the epxperts here to see if this is the problem. Also, there is a bit of hesitation when throttling up quickly from idle.
Thanks,
Les.
Ayuh,.... Stalls, 'n shuts off is the same thing in my life,... But anyways,...
Ya, it sounds like a Carb problem,...
Donno's Adjustin' is gonna fix it,...
A Rebuild oughta though,...
