Help with my VP 4.3 please. When I start the engine it there is a sound that sounds like a bucket of bolts coming from the front of the motor. We can't determine what is causing this sound. Here is a history that leads up to the problem:
1. Water in Oil
2. Took to shop: Ran compression test and dyno: couldn't find issue with where water was coming in. Took home and did the following: Replaced from the heads up.
3. Replaced exhaust risers, manifolds, spark plugs, rebuilt heads, replaced seawater pump.
4. We have pulled both belts off: no change.
5. Pulled the time cover and noticed that the chain is a little loose is it supposed to be loose or tight?
What could be causing my engine to sound like bolts?
Thanks,
Rick and Susan
Tampa Florida
1. Water in Oil
Thanks,
Rick and Susan
Tampa Florida
