D
DJ
Guest
I have an Evinrude 90 hp.-1983 model that has not been run in fifteen years. I have no idea how it was put up. The engine turns over (by hand). I have not tried the starter yet. I will replace the water pump before attempting to start. I have already replaced the lower unit fluid and fogged the cylinders through the spark plug holes. Any ideas on what else to do? I believe the engine to be a very low hour unit. It sat in Arizona so corrosion wasn't a problem
