I have a 1981 Rinker with a 4 cylinder engine (2.5??) with a stringer drive. Last year had problems with backfiring thru carb, hard starting etc. So this year before putting in water I had the entire engine completely tuned up. All new plugs, wires, ignition components, timing set, new thermostat, fuel filter and carb filters replaced, fuel water separator added.
Ran great for a weekend and then while cruising a little over 3000 rpm seemed to throttle back on its own (as if no fuel) and then stalled couldnt get it restarted. I took it back to the shop that did the work and they told me water in the gas. They completely pumped the tank for me and went back thru the carb and filters again to clear everything out.
I got it back on the lake and starts up and idles great, I can cruise at low speed all day but once I start to push up 3000 - 3500 rpms it starts to throttle back again. If a pull back on the throttle and let it recover it wont stall and I havent had a recurrence of not being able to start it again.
Theres been a few time when it hasnt been an issue at all and I almost am thinking this seems to be when in calmer water so Im wondering if maybe its not even the speed but the choppier water that seems to bring on the symptoms.
Any help is greatly appreciated, thanks!
