It is a 1984 Evinrude 90 HP V4 with VRO.
I have to replace the cracked VRO oil tank and all the fuel lines. I will also change the lower unit oil and clean the filter bowl when I drain the carbs.
Owner says it ran perfect before he got sick and also claims it was winterized that last year and has not been run since.
I am fearful of the VRO system and don't know if there is a way to be sure it is functioning right. No oil would be real bad. Does the new tank need some priming sequence? Short of what I mentioned and changing the plugs and giving each cylinder a shot of mystery oil spray is there other things I should do before I bring her back to life?
Gary
Gary
