Sometimes when I put the boat in reverse, the engine rpm's drop by half and the engine stumbles. If i take it out of reverse and put it back in, sometimes the problem repeats and sometimes it works perfect. When the engine does stumble, the drive is in gear, there is no noise, grinding, or roughness from the upper or lower unit, but the engine simply cuts its rpm's by half and stumbles until I put it back into nuetral. I adjusted the TMSC according to the OMC manual specs using the tools and everything is lined up correctly.
Ive heard that the ESA only works when shifting out of gear, but this sure seems like the ESA is activating when putting the boat into gear.
Any thoughts?
Any thoughts?
