Coastal Denizen
- Jul 8, 2011
- 3
Hi, I have a 99 Merc 2 cycle 4 cylinder 125 HP outboard on a 17.5 ft Bayliner. Had been running fine until last week when while planing off the engine would rev w/o the boat accelerating normally. I figured the prop hub was bad. Got a brand new 3 blade alum. prop and am having exactly the same problem and its getting worse. Don't hear any gear grinding etc. and shifting is normal. Sometimes advancing the throttle fairly slowly it will not "slip" or whatever and it planes off OK. I just tried a WOT run, got 5400 RPM and 46 MPH with zero "revving" sound and that is as fast as it's ever run. It seemed to run perfect at WOT. But you slow down and try to accelerate back on plane and it slips or revs or whatever. I have looked for something near the lower unit that could be causing ventilation or turbulence but don't see anything. Have moved the depthfinder pickup all the way up to make sure it is out of the way. I'm stumped. Any ideas?
