Engine revs up but won’t push the boat forward.
Digger4u2nv
I have an old mercury 7.5 hp outboard. The motor was working fine and then all in a sudden stopped pushing my zodiac forward. The engine would rev up but wouldn’t move the boat. The motor pushes the boat at an idle but does nothing when I give it gas. Is this a sheer pin issue or something worse?
oldman570
More than likely the shear pin, or slip clutch, is broken if the motor still pushes the boat at idle speed.
mercs didnt use shear pins
so it cant be a shear pin.
or a slip clutch.
if the prop hub rubber slipped, buy a new prop. or drop the lower and inspect the driveshaft to see if it is broke. if it isnt the prop hub or the shaft, its the dog clutches
