Re: Engine removal
John, I would label all wires & tubes/hoses. If you have a digital camera, take before-during-after photos.<br />I also recommend taking the least amount of stuff off the motor as you possibly can. I know space will be limited, but if you can remove the engine with manifolds/riser, front accessories, bellhousing and the such attached, it'll be much easier to remove that stuff in your garage! Remember, those Mercruisers are kinda "plug and play" motors. Disconnect throttle/shift linkages, fuel line at carb, exhaust hoses, cable to battery, and the main plug, and there isn't much else holding it in. "All" the engines wires are on the engine, and will come out with it. Good luck!<br />Have someone to help you when you remove that drive, they are heavy! Or get/make a stand for it.
