REEL-BREAK
- Jun 4, 2001
- 46
What are some of the areas of concern when doing a rebuild? This guy said if only 1 cylinder needs a piston put only 1 or if 1 needs bore .020 do the 1 is this right.Id think doem all bearings to but Seems as more poeple I speek to this is not the case with outboards.Hey Ive got a 130 yamaha Im wanting to rebuild could this be a do it yourself project given mech.inclined and using manual or no way. My engine has low compression on 2 cyl.If bearings check out and cylinder not wore would it be possible to only do rings. Give me 02 worth Thanks
