engine rear main seal ? on a 84 3.0 liter merc
Status
Not open for further replies.
supercab78
I have the engine out, pan off and seal halves out. (1984 3.0 L mercruiser) It's a two piece seal. My ? is can I use a over the counter pan gasket and seal from a auto parts place? Or is there something different about a marine engine seal? Thanks
Kainon
Re: engine rear main seal ? on a 84 3.0 liter merc
well, the 3.0 isn't used in cars ( the 2.5L was along time ago ).. but no 2 Piece seals.
You need to get the correct seal you wont find it at a regular auto parts shop, unless they sell marine parts ( through Kellogg Marine or other Sierra Marine Dealer), NAPA can get them as their Marine Parts are Sierra Marine so they should be able to get it for you.
Better yet, buy it from Iboats.com !!!
supercab78
OK thanks for the info. Wanted to get local so I can get it together sooner.
oldjeep
The rear main seal is a common part used by a bunch of GM motors. Should be able to pick a car in the 68-89 range and get it at any parts store. As for the pan gasket - perrmatex is your friend.
2 Piece Rear Main Oil Seal GM 2.5L, 3.0L, 5.0L and 5.7L
Sierra 18-1211
New in package, 2 piece rear main seal for all gm based 2.5L, 3.0L inline 4 and 5.0L, 5.7L V8 engines 1968 thru 1989
Replaces Merc Part #: 26-814622
Replaces OMC Part #: 460571
supercab78
Thanks for the new info. I thought of using just rtv silicone for the gasket but I've never tried that yet for a oil pan. Is there any special tricks to it?
oldjeep
No real trick, just run circles around the bolt holes and then connect the circles.
Only time I use oil pan gaskets is when I can get the rubber type with the steel sleeves - even then I use hi-tack on both sides of the gasket.
fishrdan
I doubt you are going to be able to RTV (only) the pan gasket on as the rear pan seal is pretty thick, something like 1/2" thick. I'd pop the $40-50 and get the marine 1 piece silicone pan gasket, a whole lot better than the $10 4 piece set. Agree about the rear main seal, common auto part, same with the front main seal. If you go the cheap route on the pan gasket, look for one from a 68 ChevyII with the 2.5 4cyl, same thing.
supercab78
It's all done. Here what I learned. 60's small block & inline 6 cyl Chev two piece rear mains are the same
as 1984 3.0 L 4 cylinder. Should of just ordered the pan from a chevy II like fishrdan said. The marine one from Felpro was nothing more than cork and rubber ends. Thanks for the input everybody.
Rusty81
Guys, this is an old thread.
In case anyone should see this forum looking for a rear 2-piece seal, the Fel-Pro seal BS 40013 is the same as the Sierra but $70 cheaper ($30 vs $100).
airshot
Consider this....look at all the time and effort it took to pull the engine, dissassemble, reassemble and reinstall the engine in the hull. Why would anyone want to go cheap so they could do all that again sooner ? Do it right the first time then enjoy your labor for a longer period of time !
Status
