Engine quit running..
floridaboat100
I have Twin Yamaha 130's 2001. I was out today running the boat after about 1 hour...One of the engines. Idle downed then shut off. I checked the primer ball and had to re-prime it. I tried re-starting the motor. using the normal choke and the one on the engine. I got it to turn over a few times at which point it would idle high then shut off again. I could not get it to start after that. I put it on the rack and flushed it and still could not get it to turn over. The other engine turned over fine. Any ideas ?
