I have a new-to-me 1997 Mercruiser 5.7 I'm sorting through at the moment.
I hade some widely varying engine oil pressure readings on my dash gauge (they seemed a little high).
At start-up and cold it would read around 60 psi; at 3000 RPM it would climb to around 70psi inching toward 80; at idle when warm it would be closer to 50 psi.
Well to double check everything, I plumbed in a glycerine-filled mechanical gauge and replaced the oil pressure sending unit with a new one. The dash gauge reads the same as before so the unit wasn't a problem.
However the mechanical gauge reads about 10 psi lower than the dash gauge.
So: 50 psi cold idle; 60 psi at 3000 RPM; 40 psi at warm idle.
The mechanical gauge readings are very stable at idle (warm and cold) and doesn't fluctuate at all so thats a good sign.
I'm running 25w-40 oil and I just changed it.
Do those pressures sound about right to you guys or is it a little high?
thanks.
thanks.
