I will be installing a rebuilt 1988 GM 3.0 liter engine and a rebuilt Mercruiser Alpha 1 lower unit in my "88 Starcraft Islander as soon as the snow melts and the temp. warms up here in northern Wisconsin. The engine has been run on a test stand and checks out good. According to Mercruiser manual, the engine needs about 20 hrs. breakin. Can some of those 20 hrs. can be put on the engine using ear muffs? Or do the breakin hrs. have to be put on the engine while it is under a load, ie. pushing the boat thru the water? Also would like to know if a full 20 hrs. is necessary for proper breakin time? If not, what would? <br />Thanks, <br />Buck
