I have a 1993 Wellcraft 182ss bowrider. The previous owner had installed a 5.0L V8 Merc and did not change the gearing. I have just corrected that problem. The next problem that I am running in to is the engine mounts. Are they the same for the 4.3 and 5.0? My mechanic says that he can not get the engine lined up to put the drive on correctly. He said that the front engine mount is adjustable for height and he already has it as low as he can go and it still needs to go further. He is talking about grinding down into the fibergass so he can mount the engine lower. Do you think he could shim up the rear mounts to get a proper alignment? We are in $2000 already on repairs. Any help or advice would be greatly appreciated! <br />Thanks,<br /><br />Kyle
