engine leaking water
nascarguynmber6
I have a 1984 OMC 350 V-8. :( It is leaking water from both sides of what i guess is called the bellow. :confused: Its the rubber hose after the manifold elbow before it hits the exhaust part to go out. Its on the port side of the engine. I am going to try new clamps first i guess. The rubber hose part isn't cracked cause it leaks from between the metal and rubber parts. Thanks for all the help i have received from everyone on here! Happy boating!!!!!! :cool:
THE BEEF
Re: engine leaking water
Might want to check your exhaust elbow for a crack.<br />Also try pulling the elbow off and see if its carboned up around the port where the water and exhaust mix.<br />Beef :D
rob935
check further down the exhaust for a blockage, there may be back pressure forcing the water back up ??
