Engine Lags when taking off...
Blu Coburn
Hello everyone. I have a 2000 Bayliner with a MCM 4.3 Alpha Engine w/ carburetor, and just recently it started lagging real bad when I take off from a dead stop to 3/4 throttle... Its acting like its not getting good fuel as it may run "slow" for 5 or 6 minutes but will finally pick up. You can notice when the throttle start to fully engage as it'll pick up RPM's - then lag back down - pick up RPM's - lag back down... and then just take off. I thought it may be a clogged fuel filter, but I can't seem to find it? It has given me any problems until recently... I've also noticed that its been harder to start. Any advice would be greatly appreciated.
Kind Regards.
Blu
Chris1956
Re: Engine Lags when taking off...
Blu, You might repost this in the I/O forum. Check to see if the accelerator pump is working. Check the antisiphon valve in the fuel tank fuel pickup.
