Engine ID
FreeBeeTony
I was looking at my engine tonight to see if I have roller lifters or not. The manual says the engine code is CD for engines with roller lifters. I am just curious at the moment.<br /><br />However, while looking for this engine code, which I did not find, I noticed a sticker on one of the valve covers with the name Dearler Marine. Looks like this engine had a long block replacement?<br /><br />Anyway, has anyone heard of this company?<br /><br />Any other way to determine which block I have?
Re: Engine ID
Hi Tony,.......<br /><br />The Best I can do for That Question is, Over Here,.................... <br />It'll explain Which #s,.. Found Where to tell you Quite Abit about Your Motor,........<br /><br />Good Luck...... ;)
Don S
Re: Engine ID
Here are the Mercruiser engine codes.<br /><br /> http://www.boatfix.com/merc/Bullet/97/97_06.pdf <br /><br />Didn't we discuss this with serial numbers on an early post about this boat? Even before you decided to buy it.<br />Check back in your old posts.
FreeBeeTony
Re: Engine ID
Yes Don, we did discuss this before I bought the boat. I have the s/n on the cover but I just noticed the sticker on the valve cover so I want to make sure what I have.<br /><br />The casting number on the back of the block is 14093638 so I know it's a 350 with a one pc rear main seal, but I don't know if it has roller lifters.<br /><br />I can't find/see the Mercruiser code on page 1 location 'b' of the service bulletin you posted. If a code is not there, would this mean it may not be a Mercruiser block?
