redfury
- Jul 16, 2006
- 2,655
1972 'rude 100hp. Long story short, bought the motor used- it didn't run right in the lake...ended up being a loose wire on the points system. Ran great in the water once it was firing on all the cylinders, but then bogged down. Water pump was replaced and got a good stream from the pee hole, so some of the worry of overheating was gone, but still wanted to err on the side of caution. Took the engine cover off to keep an eye on the engine and the bogging down was gone. Seemingly the engine cover is choking the air supply to the engine. It runs fine if the cover isn't completely snapped down with all 3 clamps, but if you seal it up, it bogs down again. Where in the cowl is the air supposed to enter, because it isn't readily obvious by looking at it.
