Re: Engine Fog
DHP,<br /><br />I've been winterizing my searay for 20 years, with no problem. Of course, I have not been performing the winterzation the correct way.<br />I simply drain the block, manifold, elbow.<br />Connect small pump to the block drain and pump entire system full of antifreeze. I have never fogged the engine, changed the oil/filter - I wait til spring to do that. The only issue I have ever had was the gas laquered up one year in the carb. The issue is, the Volvo has several more water lines that the Merc 3.0 (1984). I need to learn the proper way, and now is as good a time as any. I'm not worried about freezing up the system, I am anal about mechanical / hydronic systems, if anything I'll probably go overboard.<br />My dealer wont share any info with me, feels I'm taking money out of his pocket. So, I'll do it myself. You probably right, I should pay the $300.00 and feel good about it.
