I recently had a soft grounding. I believe the engine ingested some mud which plugged up the cooling circuit of my emm causing it to fail. My question is this: Is there a special flushing procedure that I should use other than relying on the water pump to clean up the cooling passages? Would adding a detergent to the tank be of any use? I don't want the rebuilt emm to fail prematurely because of reduced cooling flows.
