engine flooding out!
pyerardi
It's a 1967 johnson 40hp. It runs for a few seconds then fuel pours out of the hole in the picture. what could it be?
bktheking
Re: engine flooding out!
Carb has garbage in it or the float isn't shutting off the fuel, will need to be taken apart and inspected.
pyerardi
Thanks. I have the rebuild kit here but no manual yet. Was thinking the float needle too.
tashasdaddy
clean and rebuild you carb with a kit. it will fix it. also if not done, change all fuel lines to alcohol resistant lines.
see TOP SECRET FILE.
