Re: Engine dies as I put to gear
Thanks for the advise. But I have clean the carbs & bought new plugs. Still the engine dies <br />when put into gear plus now the engine sounds misfired.The local mechanic who have service<br />other mercury says it the switchbox. He has fixed a few mercury engine by changing the switch<br />box only.But the engine owner says the same problem arise when the engine was return to the<br />water a few months later and the mechanic just change the switchbox and it flies again. Can this <br />be the reason or electrical problem. Pls advise
