Engine died for no reason....
Olde Merc
This is a long post, but I tried to make it as detailed as possible to help diagnose the problem. <br /><br />I just got back from a fishing trip with my 1976 Merc 200 20hp outboard. On the way back in to the boat lauch, we tried one last fishing hole about five minutes from the ramp. <br /><br />When we were ready to go in, I fired up the engine, and it started as it did normally with one easy pull. Shortly after that the engine quickly died. I pulled it to start it agian, and it ran for about 2 seconds and then died. I pulled the cover and checked a few things, and everything seemed in order. When I attemped to start it during this time, it had no signs of firing. <br /><br />I didn't smell fuel or see any signs of flooding. I tired squeezing the fuel bulb (thinking lack of fuel was the problem) and the engine sputtered. So, I put the choke on and squeezed the bubble, and it sputtered for a few seconds this time. So then I got my friend to try to squeeze the bubble while I pulled the cord, and it started (he stopped squeezing after it started). It was running very poorly, but we wanted to get to the ramp ASAP. <br /><br />As I took off I tried shutting the choke off, and it seemed to run normal. I ran it at WOT all the way to the ramp. At the dock, I tired a couple of restarts and it started fine. <br /><br />What the heck would have caused this problem? Perhaps an air bubble in the fuel line? Maybe my fuel pump is on it's way out? I changed the switch box on the engine last year, but I don't think that's the problem.<br /><br />Any suggestions would greatly be appreciated. I use this motor fairly often and I don't want to be left stranded.
JB
Re: Engine died for no reason....
Water in the fuel could cause that.
Olde Merc
Originally posted by JB:<br /> Water in the fuel could cause that.
Thanks for the response. I am hoping it is something simple like water in the fuel. Is there a way of checking the fuel in my tank? This tank is also has a little more oil than required too, but I don't think that would cause any problem. I accidentally dumped in maybe 50ml (at most) extra oil.<br /><br />Could this be a problem with the carb? Maybe the float sticking? <br /><br />Any other advice is appreciated.
Greg New Zealand
The extra oil my be your problem. I recently put a little too much oil in and my 50 (500) ran like a pig all day. Hard to start, would die if idling too long then harder to start. Changed the fuel and gave it new plugs - perfect now. :D
andrewkafp
I've found that when you anchor for a while. That warm/cold ?? start is always a problem. I never know whether to just turn the key.. use the choke or squeeze the bulb, as My '80 50hp Merc is mostly a good starter. When faced with 40min at anchor, I always stuff it up by flooding it. You don't always smell fuel, but you usually see dark grey smoke associated with fuel/oil. I agree with Greg on the extra oil too. That may oil your plugs and make it not start. I left fuel in my 6hp Suzuki for a couple of weeks whilst towing across the hot centre of Oz. When I went to start it, I found that the plugs were oiled up and basically had to change them before it would fire.(Keep a set of spares for both motors on board) This motor always fires up 1st pull. A bit of oil on the plugs will KILL it.
