1994lundminnow
- Jun 19, 2004
- 69
1994 150 HP Johnson Searunner<br /><br />First, embarassed to admit... but tonight I forgot the plug in the boat. Luckily I remembered before things got ugly, but I did have water up to the floor boards... I guess that's pretty ugly but it could have been worse.<br /><br />Anyway, started great, ran great for a good half hour. Then during a slow troll through a no wake zone the VRO alarm sounded that there was no oil (fast constant beeps), this has happened before and I up the RPM's and it goes away (Bad idea?). So after that we were going fine for a little bit, cruising around 3k RPM's and all of a sudden the engine just freezes. Not like a slow dieing, but instantly. One second its running, the next second its completely stopped. <br /><br />I pulled the engine up to see if I'd wrapped the prop in some debri, nope. Everything looked fine, no smoke, no smells. I started it and it cranked right up. I started to accelerate again and I was able to, but then 30 seconds later, the same thing, it just froze.<br /><br />After that I swore a lot and limped home on my kicker, not wanting to push the big engine in case what I was doing would cause damage.<br /><br />When engine was running, it was running great. Smooth, no abnorminal noises, etc. Water was flowing fine out of the coolant exit, even on the second attempt. VRO is definately oiling, I keep a sharp eye on the oil level to make sure it keeps going down as I run it. One thing I didn't do was pull the cover off to see if it had overheated, although I'm not sure if I'd be able to tell hot from too hot.<br /><br />Thanks in advance for the help. I've been searching on here for the last hour or so, and will continue to do so as I can't sleep, but I can't see this specific problem.<br /><br />thanks,<br /><br />Eric
