engine cuts out
swciel
5.0,mercruiser 2003, starts every time then dies after @20-30 seconds,lie you hit a kill switch, I checked wiring, ignition switch, kill switch, HELP!!!
milkyway
Re: engine cuts out
Same thing happened to me last year. Engine died between 30 and 45 seconds. I have an electric fuel pump and the wiring connections were loose. These forum guys led me to this solution. If you have electric pump, check this area.
swciel
Re: engine cuts out
Well, finally diagnosed the culprit, it was the oil pressure sensor, replaced it and now runs fine.
hoot
Re: engine cuts out
thanks for posting the answer. helps others with similar problems.
