I'm having some trouble with a 305 Mercruiser on a 1990 Avanti 2955. My observations:
a. The engine cranks at a good rate but there is no sign of ignition.
b. I removed the top of the carburetor to check for gasoline and it seemed wet and I saw fumes rising when applying full throttle.
c. I let it sit with full throttle in case it was flooded. No change. d. The RPM gauge didn't move while cranking. Maybe broken?
e. I thought of advancing throttle while cranking. So I push from N to F but anything past F would kill the starter and the engine would stop cranking until you put the lever back to N. I guess you can't apply throttle while starting?
f. I pumped it between full throttle and full reverse. No change.
Tomorrow I'm going to drop by an auto store and see if I can rent a spark tester.
Just recently the previous owner changed the distributor cap and installed new spark plug wires. He also sent a video of it running after doing that work... and insists that it ran fine. I have no reason to doubt his honesty. It's possible I just flooded it.
The second twin engine starts/runs fine. I'm only having trouble starting the first.
Is there anything else I should try when I'm out there?
