fisherman73
- Aug 12, 2005
- 97
Well, what I thought was a case of burned exhaust valves is excalating as I've found to be a common senario with anything involving boat repair. Exhaust manifold gasket surface between riser and manifolds failed,(as Don so appropriatly pointed out, thanks Don). The trickle of cold salt water sitting on top of a hot exhaust valve was quite distructive. After removing the heads I decided to pull the starter just to clean it up a bit. Of course, I was unable to get the terminals to come loose on the solenoid, so a new starter is on its way. After the starter was out I noticed a quarter sized spot of rust on the pan, which promtly began streaming oil out when I picked at it a little. So a new pan is on its way as well. So long story longer... When I have this engine out and am doing my best to remove rust and repaint everything what steps should I be using to ensure maximum protection ? This engine was completely overhauled about 200 hrs ago and has very little of the original black paint on it. It looks like it was rattle canned then but that paint didnt stick very well and after a few years it looks like I drug the thing out of the bottom of the ocean!
