Have a 1996 kawasaki zxi 1100, a small hose (from the block) came off the fitting under the carburators, flooded the compartment. Removed drain plug and towed back to the house (under 10 mph). Found the cylinder heads to be filled with water. Removed water and tried to start. No luck. Ski attempted to start after a few tries, but won't do anything now. Any help? <br /><br />Part 2<br />After reading a few forums on a different ski, I was able to get it running, but now it runs rough and won't idle. It will go wide open throttle and run smooth. It will miss intermittently at any other rpm.<br /><br />Also the ski smokes quite a bit. This has been going on for a few years. Is there a way to reduce the amount of oil the (injector) delivers.<br /><br /><br />Thanks <br />Randy
