Re: engine can only go 4000rpm
Hi ,you said you bought it second hand,did you ever have it over 4000 RPM,like 4500 or over, the reason is if your Propeller has to much pitch ,the motor is working to hard and thats all the RPM you will get,it happen to me years back ,the boat had a 21 Pitch prop,it need it a 17 pitch, solved the problem
