Hello i am starting a new post my red lever problem was miner compared to this...
I was running my 1988 48 hp spl with new gas mixed 50 to one. The compression was 120 psi on both cyl the motor has bin sitting a year or two. Cleaned the carbs. had the engine running with water hooked up with a good stream coming out of the top pee hole. Every thing seemed fine with it running maybe a min. or less when i brought ti down to idle it stopped fast. When i went to restart it would not turn over. It would rotate back and forth but not all the way around .
Pulled the head and found table spoon full of dry alum. dust and chips in top cyl. Also some metal transfer on cyl wall . What happened and what do i do now
