captainRon
- May 27, 2002
- 1
I have a 93 rinker with a mercruiser 350 magnum engine. First time out it ran for about 20 mins. After that the trouble began. From a dead stop engine will stall when given any throttle while in gear. If i barely put it into gear i can putt around. If i put the boat into neutral, i can rev the engine up without any hesitation. Seems to be little more difficult to start than last season, but i'm not for sure. The seperator was changed out and found the fuel line fitting on tank was loose but this has not solved the problem. I can't find an inline fuel filter on this engine either. Any ideas??......Thanks in Advance.
