Engine Block Life in Salt Water
Shaun78
How long will a big block last in salt water? Raw water cooled engine. How long before it rots out?
DHPMARINE
Re: Engine Block Life in Salt Water
Actually I've never seen a block rust out.Might be possible,but usually manifolds,elbows,rusted tinware kill it first.
DHP
Bt Doctur
had a couple go 1800hrs,guess avg is 1500
Chris1956
Shaun, I agree with DHP. My '88 Mercruiser's block was OK, but the pan rotted out, the manifolds needed relacement(twice) and the starter, thermostat cover and most other perhiperal parts were on their way out. BTW, when the pan rotted out, I ran the motor w/o oil. That didn't help.
Haut Medoc
That depends on how well you flush it after each use.....
I think 1800 hours is a good estimate.....:)
