Hi all,
I have an 83 Sea Ray with an MCM120 2.5L and a first gen alpha one drive. I rebuilt the carb on day one and the boat would run great on muffs and would stay running in forward gear. On the water it would idle fine but would die with a bit of throttle in forward gear. I replaced the lower shift cable as it was corroded and seemed to be a glaring issue. Fast forward to everything hooked back up and adjusted. I start up the engine on muffs and put into forward gear and the boat seems to backfire out of the carb with plume of white smoke. I try again and have the same problem. I disconnected all cables and now I cannot get the engine to start at all. When I do crank it seems sluggish and now there seems to be a huge drain on my battery as it is brand new and has died twice after a charge in two days as I’m trying to get it started. Was it a bound up outdrive, did I uncover another issue by coincidence? Im really stuck on this one and hope someone may have some insight!
