Guys
I have the Rinda scan tool so I could reset the code, can the alarm be tested with the Rinda tool ?
The engine control module (ECM) of the Volvo Penta Electronic Gas Control s system (EGC) is designed to maintain exhaust emission levels while maintaining excellent driveability and fuel efficiency. The ECM controls the following conditions:The fuel controlThe ignition control (IC)The knock sensor (KS) systemThe idle air control (IAC)Various other discrete outputs The engine control module (ECM) is the control center of the engineand controls the following systems:The fuel metering systemThe ignition timingThe on-board diagnosticsThe ECM constantly monitors the information from various sensorsand controls the systems that affect performance and emissions.
ECM Functions The ECM Functions option provides access to a variety of EGC functional tests. IMPORTANT: Before performing any ECM or engine test refer to the engine manufacturers service literature for safety precautions and proper engine test procedures. To access the ECM Functions menu perform the following steps: 1) After selecting the ECM Functions option from the scanners main EGC system menu you will be presented with a sub-menu containing a variety of test functions. 2) Use the ?? and ?? keys to select the desired menu item then press YES.
