Re: engine alignment
well it is difficult with those pan engines they stopped making those sitting on a pan because the pans bend and mess up the alighnment, I had one bend from jumping waves once,the only way is an alighnment tool that goes where the pump mounts and lines up the engine ,it is real tough without the proper tool but I guess you can try and look through the pump opening and see if it is really off center however that won't get it perfect. just try to center it as close as possible.
