Engine alarms
Specialk281
Recently had one of my Mercury Optimax's rebuilt but constantly get alarm of 4 beeps every 2 minutes. Manuel says it is a low oil or water in fuel filter. It is neither of these. Wife is very upset because mechanic either doesn't know how to fix or doesn't care. I'm upset too but not quite so ballistic. Any suggestions? Engines are 2000 150 Optimax
alldodge
Re: Engine alarms
:welcome: to iboats
No expert here but have a look at this link and see if it helps
1999 Mercury Optimax 225 4 beep alarm
Specialk281
Re: Engine alarms
Thanks All Dodge. There were a lot of good suggestions in that post.
Just took advice from Alldodge posts about making sure oil tank on engine was full. It was not, so started engine and opened top of tank but never could get oil to overflow. Want next?
alldodge
Re: Engine alarms
Hope others can help out, I'm not a expert on the engines. The oil thing was to fill it just under full, start the engine and remove cap and wait. Did you fill the tank before checking? Also in the previous link above there are other things to check as well. If the oil canister should be pressurized and you have no pressure that could be the issue. Some of the other problems discussed were:
water in fuel separator
low battery voltage
float level switch gone bad
