Re: Emergency Starter Rope?
If the flywheel allows enough rope to get a good pull and your ignition system is not totally dependent it might help. I carried one when using my Johnson 55 with battery ignition. When I first got my boat I got an open in the charging circuit (broken wire in stator), and old trolling battery was already depleted. No amount of rope pulling will start one of those if the battery is weak. Got a courtesy tow from the rangers, and despite drifting into the "forbidden zone" on the lake we didn't get so much as chewed out. Could have gotten arrested- wildlife protection area. Volt meter was installed immediately after that escapade! Very cool rangers. Sent a thank you card via there boss- they were deserving of serious kudos. Bottom line: 1. There is absolutely no substitute for a good battery especially when your motor is computer controlled or otherwise requires it to run. 2. Experience is a most convincing teacher.
