Recently I have been doing alot of night fishing alone. I usually end up running the bayous around midnight or so. Using the lights from the houses and the moon I can usually see objects on the waters surface, but the one thing that bothers me is the objects that float just below that cant be seen.
Im considering hooking up an emergency kill switch, the kind that attaches to your body and kills the engine if pulled loose. After running in last night I realized that if I did hit something I would most likely be thrown forward and have little or no chance of backing off the throttle.
Im running a 48 SPL Johnson with Johnson controls(year unknown), but I see no provision for a lanyard. How do I install one? What wires should I connect to? I have found them for atvs for a good price that have 2 wires and there is a choice of normally open or normally closed, can these be used and if so what circuit position?
Thanks for any advice and yes I do wear a pfd at night.
Dave
Dave
