ziemann
- Apr 28, 2004
- 584
Elvin- I seek your infinite wisdom.... <br /><br />I am wondering if I need to try a different prop on my boat. I have a Nissan 50 TLDI on a Smokercraft Stinger 161(V hull aluminum walleye boat). The boat weighs 600 lbs. dry, the motor 210 lbs., 12 gallons fuel at 80 lbs., batteries at 50 lbs, personal gear 100 lbs, and myself at 250 lbs. I am estimating the boat on the water to be around 1300 lbs. + or - 100 lbs. The motor is mounted exactly as recommended by Nissan, and I am running a 11.6 X 11 prop. The motor runs at 5300 RPM normally and I can trim it up to the borderline of cavitation and get 5500 RPM out of it but am seeing a dissappointing 27.5 mph out of it max. <br /><br />When she is optimally trimmed up, a slight slide is noticable when in the corners. Outside of that, it runs like a dream, but I am a bit dissappointed in the performance. The prop recommendation came from Tohatsu/ Nissan thru my dealer who called in to ask. <br /><br />My father is running a very very similar sized Alumacraft boat with a Yamaha 50 4 stroke and blows my doors off and runs at about 33+ mph.<br /><br />Do you have any prop recommendations? Or is this about as good as it is going to get??<br /><br />And if you do have a prop recommendation, do you have it available?<br /><br />Thanks!!!!
