My Mariner 90hp 2 cycle OB229536 warning horn sounded so I took it to a tech. He said "bad float sending unit and oil lines", replaced the lines and suggested new tank, float, and sensor. I asked him to just isolate the feeding lines to the pump and I will run premix 50:1. This done, might I cause damage to the oil pump impeller from no oil feeding to it? I understand there may be prior discussion on this topic but I find no options or instructions to access archives.
